See attached documents. The first one is the Fuse 12 fix where the fuel pump circuit fails when the AC blower fuse blows. There are other threads that reference this problem, this is the solution. The second document is a mod to the first one. When Hi-Tech made the Fuse 12 kit, they used different relays depending on the production date. My car P2133 did not require the second mod. Rich Woerz's car P2197 did. I have no idea where in the overall production cycle Hi-Tech fixed this problem for cars leaving the factory but I received the fix in July 2007 and Rich's car left the factory about the same time. Conceivably, cars around P2200 should have this mod installed.
http://www.gt40s.com/images/howto/LynnMiner/Reference/SPFFuse12SB.doc
http://www.gt40s.com/images/howto/LynnMiner/Reference/HVACBlowerSup.doc
