Darius - RCR GT40 MK1 Build
could you not just cut the neck a bit shorter (but not compromising a good seat for the hose) ? On my car, there is no such interference problem.
I run the hose all the way down to the fuel tank. I removed the elbow pipe that sat about half-way down connecting two pieces of fuel hose. It was not exactly of the right diameter and I could not get rid of a fuel leak. Your idea may work as well. Just make sure the filler nozzle (at the gas station) can be inserted properly.
Randy Folsom
Need help with fuel filler cap to tank hose routing.
Mounted the filler cap onto the frame/body, but the hose has ZERO clearance to make the curve before wheel well (firewall).
Thinking of CUTTING the filler neck(blue), and WELDING(green) the provided 45' aluminum angle (red), at an offset-angle, to clear the wheel well (black).
How did you mount your 2" Marine hose to the gas filler cap and rout to the tank?
Darius,
I assume you have read the responses on FB, but I thought it might be helpful for others on GT40s to share Jeff Bruss’ post regarding the F150 filler tube option.
Darius Rudis
Just bought the fuel hose, and going to give it a try today...
Cannot link... but here is the post.
https://www.facebook.com/groups/1097214471774775/
Darius Rudis
IT WORKS !!!
I trimmed about 50% of aluminum filler neck length for added clearance.
Randy Folsom
Thanks...
Not all of us have facebook !!!
Jerry
Jerry,
The ‘GT40s Builders Group’ and ‘Race Car Replicas RCR Owners, Builders, For Sale - RCR40, SL-C, 917, etc.’ groups are good resources. Fran often chimes in on the RCR group. For me they make joining FB worth while.
Cheers, Randy
