Ford H Craft GT-R
Hello
I just put on my HRE’s. I’m having caps made that Have GT-R on them. Fitment is special. Rears are 345/25ZR20”x 12.5”, ET of 54mm. Fronts are 285/30ZR19 x 10”, ET of 32mm
The car is on blocks but settles in nicely with tires
Final pic of installation with delete plate stalled behind bumper above lower grille and below license plate grille, painted to match car color.
Here are the linear actuators in action.
The actuator mount point at the bottom bolt point has a rotation hinge that delays the beginning of the clamshell lift by 1.5 seconds so the actuators up at the latch can pull back the secondary hooks that prevent the clamshell from blowing open while the car is in motion. You can here the delay that identifies the actuators are in motion but no movement
Brian Kissel
Not positive, but I think you need a host like YouTube or something. Hopefully Randy will read and chime in.
Regards Brian
Regards Brian
Video apparently needs to be hosted offsite see attachments…
Jack welcome and congratulations on a beautiful car. H joined us for a GT get together and mountain drive while he worked there in 2019 and opened the shop up to us for a visit. I think he had just finished the car then.
David
I was there too for that drive in 2019! Awesome car, looking forward to seeing it again.
This is the finished heat shield and resonator box. The air boxes for the intake have been modified to receive the clam shell now 100% seal.
Final fitment complete and ready to clear gloss paint touch up.
Getting ready to install my carbon fiber side air scoops.
