01e trans axel with quail ATB oil
Hi all it’s probably a question previously answers in the forums but would like some input from peoples experience on gearbox oil grade and brands people have tried?
Also oil level -is it just to the fill plug with the box level?
My box is an 01e with wider 1st gear and quaff ATB diff
Thanks in advance john
Quaife :p
side note what is the 1st gear you have and where was it from? The 1/2 gears are part of the input shaft on the 01e’s aren’t they?
Quaife :p
Early 01E's had 2 different gears available in a 01E depending on the case used after the wider 1st gear appeared in late Audi S2’s, Audi dropped the earlier narrow-geared versions. B6 will have the wider first gear.
Ah ok thought he meant a non standard setup.
