Hi Jean, you could try http://www.bncproducts.com.au/transaxle_adaptor_kits.html Chris Hatfield (Flatchat) runs the company and is on this forum.hello to all and thank you for the welcome, I would like to know where to find an complete adaptation kit for 347 Ford windsor and g50.... motor have 50oz imbalance, i need all : clutch, adapter, flywheel.... thanks !
You need to be sure of your motorbalance before purchasing anything.Hi, I am looking for references for the clutch kit and a small starter for my g50 on 347 ford, thanks guys!
I thought I was up to speed with Ford Stuff, but Ive never struck 32 OZ as a 'known' balance factor? ( 'normal 289/302 & early 351w & c are all 28oz' ) 347 is usually std 4" bore and 3.4" stroke, can be 50 oz or balanced to "0' or neutral with mallory metal if you like. If you did not get balancer , flywheel etc with the engine you might be looking at a balance job anyway which will require a partial teardown.a 347ci probably should be 32oz imbalance which is not commonly known I think
( a base EFI 5L 50oz is then bored and stroked to 347ci and assembled with same flywheel and damper ) I assume ?
I'd suggest a neutral balance for that odd ball combo anyways
