What does 11219-VUS do?
That is the replacement control module for the Gen II Mini - Heat, Cool & Defrost. Each of those replacement modules are specific to the particular Gen II system configuration.
It is the control panel that you give aircon/heat input to (same button/dials that control on a regular car), it communicates electronically with the various components of the aircon/heat system engaging/regulating/shutting down to produce the cabin environment/command you gave it.
Okay, so how does that fit together with prior comments about adding a servo motor to control the manual AC knob? Or the Dakota controller?
Ahhh yes, I remember reading about that issue during my GTM research. I am curious to know what type/brand servo controlled heater bypass valve you are using. The only heater bypass valve solution I have seen is a vacuum solenoid bypass valve.
Great info Vidal. I am currently using the electronic version of the bypass valve (Old Air Products) in my engine compartment but I think I might sell it and go with the vacuum operated valve instead. I think the vacuum style product will be more robust in the engine compartment.
Wow Vidal, I just looked at your build log....very impressive. My build electrically is very similar to yours. I'm using all the wiring from a Z06 C6 Corvette.
I am using the BCM and interior wiring so that I can use the C6 instument panel and HUD. The C6 Corvette uses push button keyless start. I hope I've covered all the bases as lots of the modules will not be used. Were you able to get rid of alot of your DTCs? I didn't think HPTuners was able to get rid of BCM codes.
