Jim Craik
Hi, my alternator has stopped working, I'm in the process of removing it and I have a question.
The motor is a Roush 342R, there is only one serpintine belt, turning the alternator, AC pump, water pump and two idler pulleys.
I disconected the battery and the wire at the back of the alt. Then I pulled the two bolts that holds the Alt in place. Now I need to loosen the belt tensioner.
One of the idler pulleys has a large center bolt with a smaller bolt that is slightly offset.
I'm guessing that this is the tensioner, but I dont want to loosen it untill I know how it works and how to re-tension it when I'm done.
Does anybody have any experiance with this type of belt tensioner?
