I might try to tweak the doors in-out...depending on what is needed, as long as that doesn't affect my door seam or roof line too much. I'm thinking I'm going to have to do a creative cut and reposition for the clam corners so that I don't have to build up the fiberglass too much on the clam corner or the doors.
Kyle
GT40s Sponsor
Joe any issue with doors sagging when you open? From what I see on the AP cars the door hinge doesn’t look that beefy. I’ve got 1/2 rod ends on mine and still get play and sag when they open.
Lots of steps to get the front clam rocker latches mounted in the right spot, and then getting the latch mounted to the clam. Back and forth around the front of the car about a hundred times trying to get everything symmetrical…even though you can only see one side at a time! I mount the latch to the rocker first, then make sure the angle is correct prior to mounting the latch to the clam with fortified epoxy. Sanding starts tomorrow.
The front clam clamps and pins function as they should, but the clam sides where they meet the door are rather flimsy. I know some original cars had bracing up the leg that tied in with the top of the clam. That’s on the agenda after I get the top corners where the clam meets the doors figured out.
….and we clamp. My car was shipped without inner bracing on the A-pillars, since it also originally came with a roll cage. Chris shipped me an inner roof panel and A-pillar pieces after I inquired about finishing the interior. I started by getting them fitted using a little heat and clamping. In case I need to sand the windshield surround, I filled the inner cavity with fortified epoxy. Probably overkill for the amount of sanding I might have to do, but might as well do it while the area is exposed. I suppose it might add a little strength and stiffness too.
I also checked proof of concept for the new rad support area. Definitely couldn’t do this with the original design. I almost wonder if RCR car front ends are strong enough to use as a jacking point, or tow hook mount.
I also checked proof of concept for the new rad support area. Definitely couldn’t do this with the original design. I almost wonder if RCR car front ends are strong enough to use as a jacking point, or tow hook mount.View attachment 153691View attachment 153692View attachment 153693View attachment 153694View attachment 153695
Looking good Joe, keep up the good fight!
