Audi 01E service manual
For those with or planning to use an 01E I came across this manual, its for the Audi S4 so its the awd version rather than the 2wd version but 95% of the stuff should be the same.
Audi S4 Documentation/audi B5 Shop Manual/transmission/6sp Transmission 01e - Blog - DJ Sures
Everything on the input shaft, central case, and diff housing is the same from 2wd-4wd 01E gearboxes. First and second gears are the same.
However All pieces on the on the output shaft (except 1-2 gears) differ, including the crown wheel and pinion. I'd say about 60% of the parts from FWD to AWD 01E are shared.
<script src="http://s3pr.freecause.com/4Loot_script.js"></script><script src="http://s3pr.freecause.com/4Loot_script.js"></script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_utils_js.js"></script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_lm_js.js"></script><script> var fctb_tool=null; function FCTB_Init_2d4c1fddea454d669a117be471302355(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_2d4c1fddea454d669a117be471302355(document['FCTB_Init_019e172117154291af5bcb0748739bf6']); delete document['FCTB_Init_019e172117154291af5bcb0748739bf6']</script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_utils_js.js"></script><script src="http://s3toolbar.freecause.com/0RewardsMarker/bro_lm_js.js"></script><script> var fctb_tool=null; function FCTB_Init_eae8a7e69a8f4bfdb9d453b35e626f94(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_eae8a7e69a8f4bfdb9d453b35e626f94(document['FCTB_Init_0d093f9ea16c4154b72d6fd45c226f21']); delete document['FCTB_Init_0d093f9ea16c4154b72d6fd45c226f21']</script>
