Are you adapting to AN fitting? I tried to find one and never did. I ended up making my own. I will check on the thread and post here later.
Ill probably end up doing the same but could use the thread data for a start..... Thanks DonAre you adapting to AN fitting? I tried to find one and never did. I ended up making my own. I will check on the thread and post here later.
Thanks DonFWIW, the corresponding thread on a BMW slave is M10x1. We use an Earls 592042 adapter to get to a -4 hose.
They do make an adaptor from 12x1.0 to 7/16 inv flare. Ill post name of co. later. Thanks DJThanks DJ
