Has anyone fitted a block heater to their engine? Reason for the enquiry is that I will only run the car at weekends and am conscious of what we call "cold corrosion" The only heaters I know of are the recirculating type which means there is a lengthy proceedure to connect and disconnect.. Is there a heater probe that I can insert in the block cooling system and connect the power to and heat the engine block, without having to disconecting hoses and pump?
I am running with the Windsor engine in an RF kit.
Regards to all
Wayne
Regards to all
Wayne
