Questions from last night's wrench turning:
1. Shifter cables - the passenger side motor mount structure has these neat holes (see photo). Are they designed for the shifter cables to pass through? If so, which cable goes top/bottom, or perhaps it doesn't matter?
2. Shifter cable brackets on Quaife - I have the Olthoff linkage upgrade. The mechanism which attaches to the shifter is pretty straightforward (see photo). Can I get some guidance on attach points for the brackets? Related to #1 above, do both shifter cables travel down the same side of the engine, or are they split? I can see a case where the cables have to approach the Quaife from different angles for the action they provide.
3. Parking brake cables - do they pass under the motor mounts or over? I can see a case for either, but feel like they stay on top of the motor mount after the engine is installed.
4. Radiator hoses at the firewall - The two large hoses that end just forward of the firewall and connect to water pump and intake. Which one is which?
Thanks in advance for any help.
