I've seen some race cars where the driver was apparently happy to see the fuel tank from the driver's seat. I've got too much imagination for that, so the fuel tanks are positioned in the left and right side pods and completely covered. The fuel tanks are located with their centers on the longitudinal center of gravity of the car.
I decided the split the main side top panel in two, with the option to remove either end independently depending on which end of the main side pod you wish to access.
On the passenger side the rear lower section of the side pod alongside the engine will contain most of the fuel system parts.
On the driver side it is reserved for a future dry sump oil tank.
On the passenger side the forward section of the side pod is empty.
On the driver side an electric water pump (one of two on the car) will be fitted. This will be accessed though the panel on the front of the side pod, the panel has 2 holes for the water pipes to exit towards the front mounted radiator.
The foremost top panel, on the right is this picture, will be riveted to the chassis as it will have the body scuttle and door hinge support mounted on top of it. I have not riveted it yet as I still have to finalize the wiring harness securing / routing and this will be easier with it out of the way. The recess at the bottom is to accommodate the door edge around the hinge pin as it opens.
You may wonder at the rather fussy panel details around the fuel fillers. I originally planned to provide access to the fillers though a hatch in the covers, but then on refection it seemed that would be a hassle. You already have to open the doors to access the fillers. So then I thought to fabricate angled spigot flanges to bring the filler caps up to the top face of the top panels. I made up a template to establish the angle cuts. I bought a length of 101 mm (4") diameter pipe and had the flanges lazer cut. Fitting up the parts was complicated by the fact that I angled the fuel tank mountings in the chassis by 1.5 degrees longitudinally to ensure all the fuel can be picked up with the connection points at the rear of the tanks, and as I wanted the filler caps to sit parallel to the panels.
I then fitted up closing panels around the spigots with a 5 mm (1/4") gap to suit a rubber molding I found that has a continuous clip in it that grips the panel edge, and also has a bulb at the end to ensure a snug fit. I have put drain holes though the skin at the bottom of the side pods so that any leak inside the pods will become evident.
