M murf Feb 25, 2026 #1 Avs2 carb on a 302 ,can you use the kick down hole on the linkage to atttach the throttle cable too,?as want to re route the cable.cheers murf
Randy V Moderator-Admin Staff member Admin Lifetime Supporter Feb 26, 2026 #2 I don’t see why not as long as that part of the lever is locked to the throttle shaft. Your ratio may be a little fast though.
