Julian, we all have our own ideas on suspension settings and what works for the driver depending on his use of the vehicle. A road only car will have different settings to a track car, and again whether that is a sprint/hillclimb or race use. The GTD in standard form, whilst reasonably good in road form, has some limitations for other uses, and we have to look at all of the settings, not just caster/camber/ackermann/steering angle etc in isolation. I would start off setting a GTD castor at 4.5 degrees ( front) for road use and extend that to 6.5 degrees for track work, and set the rears to 1.5 degrees, and then play with those settings to suit the driver. Even the size of wheels and type of tyres makes a significant difference, and as the standard GTD front suspension has limited travel for radical settings, special suspension arms are often made up. As far as Ackerman on a GTD is concerned, in standard form its ****, and we rework the set up to give parallel steering for track use. (parallel to 20degrees either side of centre)Hope this helps, Frank
