Gary, this came in last week. They have cleaned and polished it.
Darrin, thanks, but the CAV chassis concept is based on the SBF block. I will be sticking with the configuration that the car is designed around. I'm not looking to do any customization. One can choose transaxle, and induction method. I am using an RBT/ZF -2 trans and Holley carb. Simple and robust, as they were back when. Someday when I get bored I may upgrade to 8 Stack FI, but I just don't see the immediate business case.
For the record, after a couple discussions with Dennis Olthoff, here is the clutch list:
Bell housing: Kennnedy (KEP) 157 tooth GT40 style
Block plate: custom Olthoff part or Quicktime RM-6016
Flywheel, aluminum 157 tooth: McLeod 563100-S
Pilot bearing: BMW M1 shaft to SBF, custom Olthoff part
Clutch disc 10.5" 10 spline x 1-9/64": McLeod 272180R - special order from Summit
Pressure Plate 10.5" diaphram style: McLeod 360048-5
Mechanical Pantera style TOB: McLeod 16525
Final assembly in the US will be at Olthoff's. Johann says he is booked up at the time my roller arrives. This is more than fine with me
Sam
