B David Drury Jun 15, 2017 #1 I've taken the plunge and ordered the forte chassis kit what size table is best for construction want to get ready for the big day Cheers
D Duncan Jun 16, 2017 #2 Hi David, I went with an 8x4 sheet of heavy ply on a decent base. Was just about big enough. Shout if you need help on any of the tricky parts. Duncan
R Ryan L Jun 16, 2017 #3 I have made mine 2800mm x 880mm This then has 1600mm sections that run across it as needed. There was some photos in my build diary but drop box has removed all the public linking so they are gone for the time being. Ryan
B David Drury Jun 16, 2017 #4 Thank you just getting prepped for the chassis build need to clear the shed out going to use all the workbenches I made out of scrap 2"x4" to build the base up and give me more room in there.
