With my SCCA 3.8L V6 Mustang I have to use the stock rocker arms. These are stamped steel jobbies that obviously have a lot of compromises. But, I do not have an alternative rocker arm that I can legally run.
The rocker ratio for these is 1.73 and they are the typical Ford pedestal mount type. I've got loads of them from pulling motors apart and want to hand pick units that have the most favorable rocker ratio.
Questions:
*Those with experience, do you see much of a difference in rocker ratio with stamped steel rockers?
*Is there a jig available for checking this out? I thought about welding up a "go/no go" spring loaded fixture that would report if one was less than the set point of the rig.
Ron
Questions:
Ron
