Thanks Alex and Will.
Here is my rationale for changing the coolant.
Its 96 with high humidity here in Atlanta recently.
On the highway - car runs well about 190-195 degrees.
Any stop and go and/or red lights and the temperature creeps up to 210.
My pyrometer reads the temperature about 10 degrees hotter than the gauge so I suspect I'm actually getting near 220.
I have an electric boost pump coming off the radiator along with the engine pump and I continually get a high temperature alarm when the weather is hot. Additionally I have two 14" fans on the radiator to help things out.
I bought 7 gallons of BeCool antifreeze. it is supposed to have special "properties" that help cooling. Additionally, my top radiator hose is worn and needs replacing, so I thought I would do it all at one time.
Temperatures in below 90 and I don't seem to have any problems.
As a side note, I have the Riccardo transaxle and 2nd gear won't engage until the temperature (oil) gets to 210. Then it's smooth shifting, but any cooler than that and it's clunky and I have to do a lot of 1st to 3rd shifting.
I was going to start on it today, but it's too hot to be crawling around in the garage. Maybe in the morning.
Thanks again for the advise - I'll update with my progress.
Kernie
