I have this exact same mill but sold by Grizzly. As far as I can tell they all use the same castings and parts. I think I paid around $800 about 5 years ago. I like it because it has a comparable size table and movement range as a common Bridgeport knee mill, but for far less cost. It is not, however, quite as well made in terms of backlash and adjustment and head perpendicularity to table. Realize that a big issue with a mill drill like this as opposed to a knee mill is that whereas with a knee mill you can raise and lower the table, you have to raise and lower the head of the mill/drill. This means you lose your "zero" because the head not only moves up and down but at the same time loosens up for sideways adjustment. You need to plan ahead for each chucking and take into account all the tools you will need so you can install / remove them and have enough vertical movement to clear and cut. Not a really big deal, just an annoyance. If you are not running a professional shop and just need to be able to make decent parts, I say go for it. Liike most mills, this one is supposedly easily retrofitable for CNC if you so choose in the future. In fact, a CNC version of the exact mill is sold, as is the retrofit kit.
