Joel K
Figure I’d pose this question. I am in the process of fabricating a fan shroud and haven’t decided how I will mount it. Looks like most builders simply weld it to the radiator and wondering if that is the recommended approach. I have dual brushless fans and they weigh 4.4 pounds each so figure the shroud with two fans will weight about 13 pounds. Wondering if that is too much weight and perhaps a better approach is to mount it on the side panels and floor of the front compartment and use weather stripping to seal it against the radiator vs. simply welding it to the radiator.
As always, appreciate everyone’s advice.
