G50-52 for sale
I have a G5052 trans axle for a pretty good price.
Specs:
- Steel synchro on 2/3/4
- Steel rear mounts
- LSD differential
- Shorter 2/3/4 gear
- First gear stock. 2e 1,89 3e1,40 4e 1,27 5e1,00
- less than 10 hours on the track since last overhaul(just track-days).
- Differential is 9/31
Production numbers on the housings are:
- Nr 964.301.101 7R and Nr 950.301.1013R
The transaxle has been raced in a previous car, but has only been driven on a couple off trackdays since it was last gone through.
I will need 6200$ for the transaxle delivered at your nearest US airport. (airfreight from Europe) Contact me for quotes to different countries.
Delivery from an airport will cost you some additional $
Payment has to be done by Paypal, or by wire transfer before shipment.
Delivery should be done less than 14 days after the payment is received.
Sorry for the advertising.
Best Regards
Kjetil
Kjetfinn@online "dot" no
Kjetil,
Would be interested
Cost including shipping to germany ?
is the gearing correct, because this sounds short and it looks that also the 5th gear is swapped.
This are the original ratios
G50/52 3.154 1.789 1.269 0.967 0.756 .
You don´t happen to have this still available ?
The 1.00 5th and 3.44 final ratio would just give 145 mph @6500 RPM with a 26" tire.
TOM
