G50 slave cylinder
I`m going to run AN4 from my clutch pedal to my G50 Slave Cylinder I`m looking for help on the thread pitch size on the slave cylinder threads any of you recall what size it is?
thank you all so much for your help. Kent
Morten
Mortified GT
Can you run a 1/4in hard line most of the run, drill out the 3/16 (M10) nipples to 1/4in
Bleed nipple is M6, clutch pipe nipple M10x1mm is my best guess.
Hope this helps, morten
Thanks for your reply Morten, I`m going to run a 1/4 hard line all the way to the slave cylinder, I`m just unsure of what size the sslave cylinder is tapped to from the factory I agree from my research its either M10 x1.0 or M14 x 1.5 I will probably just order both size fittings.
