I don't have a picture handy, but both brake MCs and the clutch MC are at the bottom of the pedal assembly. It is impossible to reach it from inside the car as the foot box essentially a small coffin. You can access it from the top of the tub in front but you have to remove the fake oil tank and the entire AC box. It will take a bunch of disassembly to get to it. But again, I would fill the reservoir and have someone exercise the pedal in and out while you attempt to bleed the system at the back end. You may get lucky. It would probably be easier to remove the entire pedal assembly if you have to change the mc. It's a bitch of a job.
I filled the reservoir and had my helper push the pedal down while I opened the bleeder valve. Then I closed it and had her pull the pedal up. We did this several times with no fluid coming out of the bleeder (some came out the first time I did it). I didn't see any bubbles in the reservoir and the level didn't change. Since that didn't work I opened up the access as you suggested. I didn't see any fluid around the master cylinder, lines pinched or any obvious damage. The pedal is pushing the shaft into the master cylinder but it doesn't feel like it is pushing any fluid. Is it time to take out the master?? It looks like I would have to move the steering shaft. Is that correct? Thanks again for your help.
Well - it could be your master and it could be the slave. Sometimes a failing master will still let you pump it up, but yours sounds like it has completely failed and fluid is bypassing the piston. I am not familiar with internal hydraulic slave cylinders and personally loath them because in order to determine what might be bad with one, you have to pull the trans and clutch.
I guess you start with the assumption the master is bad and replace it. I would try to remove it and leave the pedal assembly in place. Unbolt it from the mount and pedal and leave the lines attached to it to get it as far out of the car as you can. Then swap the lines to the new one.
Before to do this I strongly suggest a last move.
Try to push liquid with a syringue. Syringue will replace your master cylinder. Connect the output of the syringue on the flexible hose that comes from your brake fluide reservoir and try to be sure to avoid leaks. Then with the syringue full, push gently the fluid, do not do any action on the pedal. Refill the syringue if require. The liquide shall go out of the slave cylinder (bleeder is openned or even removed it to be sure). If the liquid goes out it means that your master cylinder is probably dead. But not sure, because it still can be a bleeding problem. After this, reconnect the master on its reservoir and do a bleeding test with your helper. If it works, you solved it if not , your master is shurely dead !
This means: almost certain it is a failing break master cylinder - get an identical unit (identical bore !) - bench bleed it (actually, adding some brake fluid to it should do), install and bleed the system. Once you build up pressure in the system other leaks may appear which then need further attention...
no big deal if you are somwhat ``mechanically inclined" . In this case a rebuild kit for the MC should do. Keep another for a spare.. ... best wishes!
