Other than that i have a Quaiffe ATB Diff and a oil cooler setup installed. The oil is taken from the diffhousing and reenters at the endcap, so flowing through the whole gearbox. No spray bars installed.
TOM
I would be concerned that this might create a lower than desired oil level in the diff housing/R&P area when in use, the situation could arise under acceleration where the R&P area could literally be pumped dry & the lube all stacked up in the rear of the trans housing, a 'TEE' with hose to spray R&P would help if this occurs.
