Paul Robertson
I am starting a new thread about my clutch replacement. I started a new thread rather than muck up Johns group buy thread. I replaced the stock clutch that came with the Graz transaxle from RCR. I pretty much only drive my car on the track (about 97% of my 4000 miles on the car are track miles). I was unhappy with the clutch engagement feel in high torque situations like hi speed upshifts. The stock clutch would slip just a bit. very tolerable but I had the engine out so I decided to take that opportunity to change it. Good news was the original clutch had very little wear and the flywheel was like new after 4000 hard track miles. My LS puts out 540hp and 560 tq so the clutch sees some juice.
I sent my clutch to GTE engineering (in Pompano Beach, FL, 754-205-0812) for relining. I went back with a ceramic/ kevlar mix. Ceramic one side Kevlar on the other. $2000. He uses your stock unit for rebuild. If the springs in your unit are shot then you will have to purchase a new unit which will drive up your cost. I have about 500 track miles on the new clutch and I see improved engagement characteristics both at high torque and low torque settings as well which surprised me . It feathers as well if not better than the stock unit.
