There are a few running around.
Ed Davis has one that another owner has driven/passenger in.
I am sure he will give you his opinion.
There are higher V10 ratios available for the upper gears and also even higher custom 5/6 gear sets for the big mph guys running Lamborghini's/R8's
I was just about to ask you whether the boxes that you offer were the standard gears or the taller gears used in the Lambo's.
RPM's:
The Audi V8 engine, (at 8250 max rpm), revs a bit higher than the Vette LS7 (7000 max rpm), and the V10 revs higher yet (8700 max RPM), so the 2 or 3 thousand dollars above with the cost of the standard ratio box, or just spring for the transaxle with the taller gears? I guess that's really the first question. The 2nd is whether or not the Lamborghini transaxles would still benefit from the step gear kit.
I'm sort of guessing, that unless you use an engine that will spool up to 8500 to 9000 rpm, the Graziano with standard gear ratios would be the better bet when paired with the LS engines.
Weight:
The Aventador weighs in at about 3475 lbs, and the Huracan is around 3150 lbs. So I guess in the SLC, there would be even less stress on the gears.
Either way, it is a gear box that can easily handle the load that these cars generate. I think the Lamborghini's are at least 800 lbs heavier than the SLC.
I wonder if it would fit into a GTM? :thumbsup:
Just thinking out loud...
