Re: Possible Suspension Arm Failure, Racing - Tornado GT40
Dear all
just one point from my side. We have to differentiate Spring and shock and positioning of Spring along the shock absorber. Spring preload ( or changing of spring preload by changing the lower platform level) is not changing the total travel of the spring and point of load where it goes coil bind. As the words says it is only changing the preload which has to be overcome . over all the spring at a given load above the preload will always have the same compressed length.
So first of all the question must be answered , is the spring the correct one. A to weak of a spring for a given load will always go coilbind, independent what preload it will be given.
Secondly. if the spring is to weak the shock can go on block. Same will happen if the spring is to postioned to low on the shock , the shock will go on block before the spring goes on coil bind.
Therefore i can not fully agree to some reasonings in previous postings
TOM
Dear all
TOM
