Hacking an IDA 'Weber', turning it into EFI
I must say that this is really inspiring, what is the estimated cost of the completed ITB's?
Might even consider changing my approach for Retro looking EFI to ITB if it is a cost efficient way to save money and poor in some extra time and effort to build myself (like you did)
I think i'll be in approximately 3000-3500 in the end. The intake casting is about 800, the webers approximately 1000 from china. The injector bosses approxmately 300. The throttle kit approx 400. The shaft seals were 50-ish if I remember correctly. Then there's the plethora of small items (AN fittings, alu tubing, etc.. ) which I didn't keep track off.
I don't think its much cheaper, but it is definitly a lot of fun. Also I think they will work better than the borla weber look-a-likes, as the injection is downstream the throttle plates, not right on top of them. The Inglese version is the Borla version I think, or you're referring to the IDA ones that don't look like webers?
Do you have the article number for the correct intake casting?
