Ken Roberts
Looking for some advice on how to modify the low beam modules.
I understand how you are supposed to cut one of the 4 legs off each module to fit due to interference with the fiberglass (10 oclock position for left side) (2 oclock position for right side). The problem is the housing on the low beam projector module isn't the same as the housing on the high beam module.
The high beam module body is one piece while the low beam module body is made up of 2 pieces. The assembly manual shows them both being the same (one piece) (i guess they didn't use a projector low beam in the picture). The high beam module is easy to work with. Just chop off one leg, nothing else protrudes. The low beam module has more parts that need to be removed to fit where it needs to go. If you remove these parts then the two piece housing will only be held together with one bolt. The two other bolts need to be chopped off to fit. How then do you hold the housing together?
Here is the one piece body of the high beam housing...easy just chop one leg off!
Here is the 2 piece housing of the low beam. My 2 fingers and thumb are touching the areas that need to be removed for clearance (for the left side).
Here is an addition view of the differences.
