Seymour Snerd
I'm fitting a ZFQ transaxle to a Quicktime bellhousing, in turn behind an FE engine. The Quaife cross-shaft comes with a clutch arm leaning outward about 45 degrees in order to accomodate the Quaife bell housing's method of mounting the slave cylinder vertically on the bell housing.
In my situation it makes more sense to mount the slave cylinder longitudinally beneath the half-shafts, and for that I need a "straight" clutch arm. I'm a bit at a loss as to where to look for one to fit the Quaife splines. The cross shaft splines are 0.58" dia, 39 splines. Arm length needs to be about 2".
Where, other than Quaife themselves, would I look?
(Why not Quaife? They have a somewhat-usable alternative, but its delivered price to USA is simply stunning.).
