Dan Kasten
After reading a post the other day I got to thinking, why is my car so hot inside the cabin. At first I was thinking that it is just engine heat coming through the firewall but now think it is a totally different problem. I was looking at the depth of the nostrils and realize that they only go down about half way on the radiator leaving the other half blowing under the bottom of the nostrils. I am thinking this heat that is going under is getting into the cabin. Has anybody had this problem as well? If you look at the picture you will see that I have a scoop on each side that has to have the heat from the radiator pumping out of these scoops and blowing in through the door jams. Do I need these scoops? Do the other cars have them? If I block them off will it give me more problems? I have to tell you that it gets so hot inside it could give you heat stroke. Before you ask, yes the car has a/c and it works, however my face stays cool and the rest of my body is as hot as the engine.
