Johnny Joints
For the all knowing engineers on this forum
Would these joints be any good for suspension joints on a GT40 as opposed to spherical rod ends?
They give about 30 degrees unidirectional movement which is greater than the common 22 degrees in a rod end. Don't know if this is particularly useful on a GT40 though.
Julian
Due to their construction in comparison with heims (rod ends) they will probably be a little less harsh at transferring road vibration through the car.
JJ's are also rebuildable, whereas heims are a replacement item.
I was thinking about them for the rear suspension where I'm currently on rose joints and would think that for road use they would give a longer life span
They are expensive though and I could probably change rod ends a couple of times for the price of Johnny's but perhaps the Johnny would last 4 or 5 times longer?
