Awhile back I had mentioned my displeasure in what appeared to be some lifting of the paint and at the time questioned paint prep. Now that I am a little deeper into the car I have found what is causing the paint to lift on the front left part of the chassis. It appears both brake and clutch reservoirs are leaking around the caps or through the vents. Does not appear to be any o-ring sealing just plain old threads. Reservoir levels don't seem overly high. Is this a known issue and are there better caps or ways to seal? I'm going to have to scrape a lot of paint off the chassis, clean everything thoroughly, and repaint the affected area. Not particularly pleased :blank:
