More info on Levy Racing Engine
The block is a Ford 9.5 deck height aluminum block. This block can go to 454 CID, but is 355 CID in this application.
The heads are Brodix-Neal BF200's. (Banned from NASCAR because they flow too much.) Intake is about 400 CFM. Titanium retainers. Custom Levy Racing design camshaft.
Aviad dry sump setup.
Headers custom built for this application.
When hooking up to the dyno to get all the fittings set up and to do some engine braking in, a pull was made to about 700 RPM below peak HP. Without any carb or ignition adjustments, 650 HP. I'll post a full dyno chart after the hard pulls on Monday.
Won't say how much money to build, but you can see it wasn't cheap.
Levy Racing can build anything you want from mild to wild. And in any price range. The good thing is that no matter what you want, Gordon will see that the package is designed so everything compliments each other. That is where the real HP and value happens. Everything turns out to be fluid dynamics.
I would give Gordon a call if you are considering someone to do an engine. Even if he doesn't do your build, he will give out good, solid advice.
