LS7 Take Off Parts
Here are new "take off" parts from my LS7 Crate engine:
Alternator: $150
Alternator Bracket: $75
Dry Sump Pan with windage tray: $325
Internal Oil Pump: $$375
External Oil Reservoir: $100
Power Steering Pump/Pulley/Reservoir: $200
Camshaft, lifters, push rods, rocker arms, fasteners: $175
Intake manifold, throttle body, fuel rails, injectors: $325
Clutch, Pressure Plate, Flywheel (has light storage oxidation): $550
Exhaust headers: $300
Also: How about a little "wheezer" M90 Supercharger (rebuilt): $300
I have full set of calipers from '01 Viper ACR $400, set of Wilwood calipers (without pistons) for same $100, center console fascia and rear bulkhead fascia.
All stored in my shop near San Angelo, Texas, USA. Reasonable offers accepted!
Ken,
Steve has tentatively purchased the intake. Let me know if you would like the alternator and dry sump reservoir without the intake. I will let you know if the intake comes up for sale again.
So I don't sell you some parts that won't work with your SLC, let me clarify:
The alternator and bracket won't fit the SLC driver side upper frame.
The oil reservoir MAY be too small for track use and MAY be too tall for the engine compartment.
Please check with someone more knowledgable than me for LS parts compatibility issues.
I'd rather have to store these items in my shop than misrepresent my parts or myself.
Doc Kaler
Ken..
Personally I would not use the ZO6 dry sump tank for an SL-C...as Doc stated its probably not large enough ...if you planned on ever doing any track days I would use a Peterson 3 gallon tank.
Many factory 2006-2008 LS7's had oiling issues due to the oem. dry sump tank volume only being 6 qts...and the total system only holding 8qts ..
Stock LS7 tanks, at least in original spec, apparently do not do a great job of de-aerating return oil, which can lead to foamy oil being fed to the engine, with bad results.
