Bob
Phil is reasonably active on this forum
The V8 Owners Forum - :: View Forum - Engines Area
Goes under the username Dax Tojero
Good reports on his products
His own site is Extra Efi.co.uk
I think Extra EFI and my ebay find are the same Ian . This is the return Email from Extra EFI.
Bob
Hi Bob,
what injectors do you have, are they the standard Bosch style
connectors or are they something smaller?
A loom works out around £200 inc connectors for a V8.
Air temp and coolant temp sensors are £35 for a pair.
A 36-1 wheel, bracket and sensor is £105, but this would be for an RV8,
so you may want to select a different size wheel and make your own
bracket for the sensor, see here:
ExtraEFI.co.uk HOME
An MS2 ECU to run it all is £415, plus £18 postage.
You will need a wideband lambda sensor to tune it with if you want to
do it yourself, these I dont sell but are around £180.
You will also need a TPS sensor, again I dont sell these but you may
have one on the ITBs.
thanks
Phil
