Monocoque Measurements
Top hole is 470 c/c to floor.
midle hole 460 c/c
Lower hole 450 c/c
Could be advantageous to wait with these holes until you have the steering coloumn to fit as they should be on 9.28in radius from top bracket mount. But all depends on coloumn fit.
Thanks , I have the steering column in the works I made the brazed on brackets and collecting materials to jig up the column. Once I have column made I'll make up the column mounts .
Threadjacking David. Does anyone have any useful information on these plates underneath the dash top?
I guess the hole should be 3,25" or so in dia.
On the first picture it is alligned so the flange is approx paralell to the suspension bracket outside.
On the last it is made as simple as possible.
Or are none of these even close to correct?
Does a 3.25" hole allow the duct on to the back of they eyeball dash vent. I cant remember the size of duct work needed. Have you drawn the extension tube off the back of the forward triangle? I think I made my hole slightly larger in that area, and may have even had it turn the corner of the flange slightly so that I was not trying to bend ductwork at an angle coming of the back of the stub tube on the back of the triangle piece?
It was so long ago that I looked at that part I can't even remember what photo I copied.
I can't even remember of the top of my head what size I made that hole.
I think I would have made it match the holes on the spare tire well cut out, just for consistency. My assumption at the time is that they would have used a punch tool that they had on hand, so just used a size that I knew they had.
Got some reliable picture info last night, will update when i have completed it. Hopefully this evening.
Here they are. Some plates removed to show them more clearly.
Some minor adjustments still needs to be made to other panels here after they where drawn.
Anyone got length of the radius rods? I found a spf drawing for it here, the upper one is 825mm c-c on the rod ends. 29" length of the rod seemed ok. The lower one approx 2" shorter if i recall right. Can anyone confirm length of the radiusrod?
HI Ole , did you get the lengths confirmed.
Looking for location and length of stiffening ribs (4) on out side skin of fuel sponson.
Veamos si se carga esta imagen. La vista es normal hacia el costado de la caja de pie donde se encuentran los orificios de 3,5".
Foot Box es como he estado llamando a esta parte del automóvil, no estoy seguro de cómo se supone que debe llamarse ya que no tengo el dibujo original para hacer referencia al título del dibujo.
<a data-flickr-embed="true" href=" " title="Cuadro de pie_230125"><img src=" https://live.staticflickr.com/65535/52645730472_9fac962bd9_h.jpg " width="1600" height="1252" alt="Cuadro de pie_230125"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>I'm looking for this drawing but I can't find it and I'm sure I have it?
I would like to get the dimensions and angles of this drawing?
