For those of you using cables for your shifter, I have a question or two. Most if not all are probably using Morse cables. Which size are you using, the 33 or the 43. Both are for shifter aplication but the 43 seems to be a little stouter. The 33 is often used for throtle aplications. The threads are a little different with the 33, using 10-32, and the 43, using 1/4-28 indicating the 43 is thicker. Also, do you use bulkhead ends to secure them or is the clamp good enough? The area where the clamp would go seems to be indented for good grip. The price difference is pretty significant. Thanks in advance.
