Whitehorse Industries is the leading metal spinning and metal fabrication company in Melbourne. We provide a wide range of high-quality products with attention to detail. Call us on 03-9739-5955 now!
have dicided to have a go at an alloy body for the Lola rep made a start last week if it does not work out will still keep the glass one as a back up
chris
finished off the intake system this morning ecu is all wired some fuel lines cooling pipes and a temporary fuse panel and i should be good to make some noise
chris
i have not thought that far ahead yet Jim i would like to turn the velocety stacks up verticly but have to work that part out yet i would also like to cast up some slide throttles for it for something different but once again not sure how you seal those things and still have travel
pulled all the panels of the Lola rep so i could finish the chassis rivetting and also make the supports around the front steering hoop support
have also cast a set of slide throttles and machined one side up and it seems to work as i had hoped
chris
