FINALLY!!!!!!!!!
The car is running at 100%! Or at least VERY close to it. Like I've reported on here before, I checked all the wiring I could for voltage and to make sure there were no kinked or cut wires. After talking to a guy from lnfforums, we concluded that since it's not a vacuum leak, the wires are fine, etc, he said that the most common issue with this engine is the MAP sensor. I unplugged it, took a look at it and inspected it the way he told me to. I plugged it back in and BAM!!!! Runs like a champ.
WHAAAAAT THE HECK DID I DO?????
So while it's running, I decide to fiddle with the connection. It runs like poop. I shut it off, unplug and replug it back in, and fire it up. She runs like a champ. I revved it a few times and it sounds just like the "stand alone lnf air boat" from YouTube. Im thinking, "okay, time for a test drive".
Zero to sixty???? No kidding??? EASY THREE SECONDS!!!!
Once again I topped off in fourth gear and shifted into fifth and it was climbing faster than almost anything I've ever been in.
So there you have it. Now I just need to figure out how to make that connection 100%. It went into limp mode once while testing. But just a simple unplug/replug and it was back to LUDICROUS SPEED (Spaceballs).
