Ken Roberts
Starter bolts for a Ricardo are M10x1.5x35mm
Here is the Ford part number for them W500120-S427
They get torqued to 35ft/lbs
Kernie, what did you find on Ebay ? Starter ? In post #24, I mentioned that I had found some factory starter bolts. Below, you can see this didn't happen. I will follow Kens advice, and buy some flanged metric bolts from Mc Master Carr. If you are looking for the slave cylinder, PM me and we can discuss a possible option.
Regards Brian
Thank you for ordering parts with us.
We are writing to inform you that order CF826605 has been voided. Your order has been voided because of the following reason(s): The ordered part(s) have been discontinued (no longer available) and/or is back ordered with no ETA date by the manufacture.
If you have further questions, contact us.
Customer Service
Apparently, the squeeze that Ford is placing on parts has been recognized by the aftermarket- you can buy, for example, Centric-branded clutch slave cylinders on eBay (from JC Whitney!). I expect more of the easily-reproduced parts to come available in time. Probably no hope for a new transaxle, though.
Brand new shiny starter showed up today. Took about 40 days to source it. Ended up at Silverstate Ford for around 300
I am going to send the old one out and have it rebuilt as a spare. Anyone have a shop they recommend.
Thanks again for all the help - this was a difficult find
