FS USA New Mallory Comp Fuel Pump, Series 140
I have one new Mallory Pro Comp Series 140, Fuel pump left, sealed in the bag.
Part # 4150, 140 gph, 12 psi max, 3/8 NPT
From Summit:
Mallory Comp Pump Fuel Pumps 4150 - SummitRacing.com
These Comp Pump series electric fuel pumps are ideal for high performance street or race applications. They have a high-quality, permanent-magnet 12 V electric motor and feature factory-set base pressure. Intended for gasoline use, each pump assembly features a quiet, high-efficiency Gerotor design that provides stable output. The housings are fully machined and have a special design that allows for some adjustment of the output pressure. All Comp Pump series fuel pumps must be used with a fuel pressure regulator. The pumps are available in many different ratings, from 60 to 500 gph, with fuel pressure ranging from 4 to 100 psi. They're perfect for any carbureted or fuel injected engine!
Summit currenlty selling for $235.95. I'll sell it for $175, plus shipping from Colorado.
Tom
Doug S.
I have this unit in my Cobra...high quality (protected by a Mallory billet fuel filter) and reliable...highly recommended to anyone who needs a good fuel pump!
Cheers!
Doug
You might want to add that since it is a Gerotor design, this pump will also LIFT fuel - meaning that it can be mounted above the fuel tank/cell without burning itself up eventually like most vane design pumps do. (and they are very quiet compared to most)
This makes it a perfect pump for a GT40.
