Original style Grling master cylinders: Where?
Hello!
I am looking for a source able to provide the original styles girling brake master cylinders, in 7/8 bore size.
I think they were used on some Austin healey 3000, but I had no chance on the net.
You can find replacements, but they don't have the correct shape arround the inlet port.
They are shown on plate P of the orig parts manual.
Any info greatly appreciated, especially if you can point me to a source which will not ask me to part with a leg!
Regards from France
Olivier
Guys, thanks for the replies, but what I am looking for is part 56 in this pics.
This is a Girling master cylinder, and has a flatmachined onto the inlet boss, with no ribs unlike newer productions Girling...
Ian, thanks again for taking some time to reply, but unfortunatelly, the parts I am looking after seem to be NLA and my only chance would be someone would have some in a cabinet, or a company with NOS ones...
Anyway, thanks again for the help!
Olivier
I see, you're a purist ;)
Here is the exploded view of a girling Brake MC, used in Austin Healey 3000 Mk II, 1961-on... 7/8 bore.
The Girling part ref is 3110421W.
Hope this helps ! (But I doubt you can find some brand new units, or maybe NOS parts ?)
Mike Pass
Check whether the outlet pipe fitting is 3/16'or 1/4". 7/8"master cylinders were made in both these outlet sizes. The larger 1/4" were usually used used for the clutch as the larger pipe flowed the fluid more easily and helped the clutch action. Post what size you need. I have some Girling master cylinders in the garage and I will check to see if I have the one you need.
Hello everybody,
First thank you all for your help. I have checked each proposition, and so far I havent found anything fullfilling my needs...
I had a deeper look at what I need, and the bore size I am looking for is not 7/8 as previously said but 13/16' which looks to be a bit weird, and definatelly not an Healey application...
The healey shape is the right one, but bore size is not. So I am back to the beigining...
The one who will point me in the original application of these weird master cylinders may win a good bottle of wine....
Olivier
