It has been a few months, but I am making steady progress. More panel fitting and a few new parts.
I now have two low pressure fuel pumps - Facet Red Top "Competition" or "Works" kits, which include an extra filter, vibration dampeners and hosetails. I will probably swap the push fit fittings for AN6 fittings.
https://www.burtonpower.com/facet-electric-fuel-pump-kit-red-top-works-6-7-25psi-fac480532k.html
I got my dashboard from AK at their Open Day this past weekend, and the seatbelt fitting bar.
I also collected four CV joints - J&R CV Joints, part number JR454. I know AK have to make a profit and external parts will have a mark up, but do yourself a favour...
https://www.jandrcvjoints.co.uk/catalogsearch/result/?q=jr454
I have been slowly continuing fitting panels to the chassis - roughly one per week(end), so here is 5 weeks work!
Another milestone piece - upper rear bulkhead panel. I decided to fit the upper panel over the top of the lower panel so there was a softer edge for when I fit carpet across the whole piece.
I started by lining up the lower edge of the bottom panel with the bottom edge of the lower rail and drilling the bottom row of holes. Then I lined up the upper panel and drilled the vertical holes. Finally put the two together and drilled through both panels and into the chassis for the middle row.
Also drilled the brackets for both fuel tanks, and ordered some 3/8" UNF Nyloc nuts (once I worked out the thread size). The breather pipe is very close to the inner bolt so will have to make some decisions when it all needs tightening up.
Was I naïve to think these would line up? It appears the measurements from the left and right hand edge have been swapped - either for the panel or the fuel tank. I will probably make a larger opening with cover plate anyway. How often will I need to pull the fuel tank float through this hole?
Everyone's favourite panel! There is just enough flex to be able to fit this panel without splitting or elongating any cutouts.
Lastly, working back at the front on these inner panels. Because of the angle inwards as the panel moves rearwards, I have added a fold 1" from the leading edge so the front edge of the panel lies flush with the vertical rail and the rivets can sit flat.
