porsche 915 trans axle
Does any one know if the porsche 915 trans axle would be good to use I think it is out of a 1974 car.
Thanks Earl S.
Earl
There are others who know better than I about whether the 915 would make a good choice. There was quite a discussion a while back. If you would like some background of the porsche units take alook at Renegade Hybrids. They work mostly with Chevy engines, but they also have info about Fords. A good primer of sorts.
G
Guest
Guest
Earl,
Also check Kennedy Engineering's web site. The 915 has been used in GT40s. That much is a fact. There is a guy in Nashville who has a DRB with a 915. Only issues,that I know of, was in converting it from cable clutch to hydraulic; as you can imagine, it took a little engineering and a couple of iterations, but I think it is working fine now. I hope to meet with him Thursday afternoon. If you'd like, I'll ask him about talking with you.
One thing about the 915, it is much cheaper to change the gears and diff in it than the G50. It does have a little lower torque rating, but our bretheren across the big pond have proven that this is not necessarily a show stopper at all!
I have the 915, it is a good strong tranny. They changed the final gearing in 77 to make it a bit stronger. It is good to 500hp (I'm told)
