Problem with coolant hose
Installed my engine, and attempted to install the upper hoses from the thermostat housing to the transfer tubes in the tunnel. But lo and behold, they protrude into the cockpit!!!!!!
What are my options?
Do they make a different water neck?
Ian Clark
Hi Bill,
I imagine Fran has a fix for that:) Attached pic shows our short accesory drive package that accomodates forward and low (correct) engine placement. This setup will run with an almost flat firewall panel, only about an inch protrusion needed to clear the water pump nose and a/c pump clutch. There is all kind of space for air circulation to minimise heat soak.
The A/C Bracket is a CAV Canada part that fits any small block Ford water pump and aligns with all pulley configurations, very trick part.
Your simplest suggestion would be a horizontally oriented water outlet fitting rather than the OEM Ford part pointing strait up, works in a Mustang but this is whole different horse. Could be custom fab part but simple enough to make. We do that kind of work too...
Bill:
I had the same issue. I wanted to keep the thermostat in the 'standard' location, so opted to modify a standard thermostat cover.
Finding a thermostat housing that would fit proved to be a real challenge. We finally settled on a generic housing (Stant 31418) and then cut out a notch and re welded it with a 30 degree backward angle.
I had a local welder cut the fitting and do the welding. For a pro this is an easy job and he did a nice job. I did make very detailed drawings so there would be no confusion.
A 180 degree thermostat was used. A standard Ford 302 bypass hose was added.
Even with this set up, the thermostat cover protrudes about a quarter of an inch inside the car, so a small ‘bubble’ will be added to the removable fire wall, similar to the bump to clear the pulley. I estimate that I will cut out a section about 6" long by 3" high and bring it in about a quarter of an inch. It will have no effect on the passenger seat and should be fairly inconspicious. This arrangement is tight, but there is enough clearance to, hopefully, avoid any problems.
I will make sure that the rubber hose does not contact the fire wall to avoid any wear due to engine vibration issues before this project is complete.
I looked a long time for a prefabricated fitting without success.
Your hose goes the other direction, but I expect the same approach would work for you.
Since you have a ZF tranny the mounting location of your engine may result in a slightly different configuration.
If anyone comes up with a better solution that keeps the thermostat in its 'stock' location I would sure like to see it.
A couple of pics follow. More on on by build log. Good luck.
Chuck
Ian:
Guess I need to eat my words. You appear to have a solution ready to go! Wish I had known about that before I went to all the trouble . . . . .
Queston: from the picture I cannot tell if the housing has room for a thermostat, although it appears to me that the thermostat would be external.
Chuck
Gregg
Gregg
Chuck, look at the firewall on the CAV again. From memory, I thought the RCR firewall is on a straight angle while it appears the CAV firewall has a bit of a curve to it. Love your build thread by the way. Top shelf all the way.
Gregg:
I believe you are right. The angle of the CAV firewall and the RCR firewall are different, although I am not sure how much difference that would make with the top hose configuration.
Chuck
Gregg
Gregg
Chuck, in the end it really doesn't matter as you, Dean Lampe, Ron McCall and others have each solved the concern, if there was one, in their own respective ways. Keep the pictures coming.
Bill, I sent you a pm.
Ian Clark
Hi Chuck, Gregg, Bill
Here's a couple more pics of the same install. It's easier to see the angle of the firewall (30degees) and the low engine position. The bulkhead windows on virtually all GT40 replicas are in the same place so that's a better reference point to guestimate by.
On the intake manifold and thermostat, there is roon for the thermostat and it's a Weber manifold so the area around the thermostat housing isn't quite the same.
The picture of the engine side of the firewall panel shows the relief for the A/C clutch and lower water pump pulley. The top half of the water pump bump could have been taken out completely but wed already had enough fun with fiberglass.
Bill, looks like an electronic distributor, what is it? I tried the MSD Electronic unit but it was WAY TOO HIGH so we went with the standard part and a 6AL
Jim Dewar
That's the one I used, the big advantage was the removable heater bypass nipple which isn't used on the RF cars. I ordered a plug to replace the heater nipple which allowed me to swivel the large hose nipple in the perfect position.
Jim,
That's actually the thermostat bypass hose. Not sure why you wouldn't need it? It is a function of the engine, not the vehicle.
Jim Dewar
Sorry Mark, I must be mistaken about it's function. I incorrectly thought it was the warm water exit from the intake through the water pump to the cars heater core. We plug both the thermostat housing and both water pump inlet and outlet tubes.
Again, I apologize for my incorrect post!
Jim,
Don't worry about the post, if you plug all four ports then you are plugging the bypass also. I always thought you had to have some coolant bypass the thermostat. It may be me who should apologize!
Jim Dewar
My bypass is #4AN hose from the two rear corners of the intake manifold to the new CSR radiator outlet pipe to bypass trapped steam at the intake manifolds highest point.
All,
PI Motorsports (principally a Pantera shop, also formerly a CAV dealer) in Orange, CA makes a bolt-on thermostat housing for putting a 351W into a Pantera, and also used on their CAV cars. It covers up the bypass orifice, meaning you would have to plug the corresponding inlet on the water pump. The main water hose exits 90 degrees to the right.
They have boxes of them on the shelf, as they are made in bulk. They don't list them on their website however.
Contact info is at Pantera, DeTomaso, PI Motorsports
I would presume that you would want to modify the thermostat to enable it to flow some water even when closed, since the stock bypass is no longer in play?
