Radiator on my Gt40
Vinny P
Here are a few photos…
It measures 28 1/2” x 12 1/2”x 1 3/4”. The inlet/outlets are 1 1/
PM me if interested. $200 plus shipping.
View attachment 150962View attachment 150963View attachment 150964View attachment 150965
Hi Vinny, i was loolong at these radiators and the price just seems to be too good to be true. Have you received the rad yet (i know its coming from china) what does the quality actually look like?
For the price it might be worth a punt anyway and just swap it later if its not up to the job?
I purchased the 3-row radiator. The quality looks good. I started the install. This is just a mock-up, I have many more photos of the nearly completed install but I am having a problem uploading
Vinny P
It worked out well mounting the radiator. I have not added coolant. I will let you know how it turns out once I do. I replaced the AC hose going to the dryer with a hardline. I may reroute it below the suction line before I charge the system. I fabricated a bracket on the right side and had to drill new holes on the left side of the car, pretty straightforward. The extra tabs that were welded on the upper and lower sections of the radiator worked out well for mounting the condenser, and also if you want to hard-mount your fans.
Vinny P
This is the final installation of the 3-row radiator, inlet/outlet at the bottom. I decided to run both ac lines alongside the radiator for a cleaner look.
Randy Folsom
Vinny, have you been able to verify that the radiator is truly a multi-pass or at least that lower input is internally going to the top such that it is a cross flow? Cheers, Randy
Czy ktoś ma oryginalne wymiary grzejnika? Potrzebuję oryginalnej dokumentacji. Chcę, aby grzejnik wyglądał dokładnie jak oryginał i, jeśli to możliwe, poprawić jego wydajność.
Randy Folsom
Translated by Google from Polish
Does anyone have the original dimensions of the radiator? I need the original documentation. I want the radiator to look exactly like the original and, if possible, improve its performance.
Vinny P
photos of 1966 Ford GT40 P/1067. road car Gt40
(Zdjęcia Forda GT40 z 1966 roku, numer P/1067, w wersji drogowej).
Vinny P
This is what I found online.
The exact factory‑issued 1966 GT40 radiator drawings are not publicly released, but the closest verified data comes from Serck (the original supplier) and period‑correct Mk I/Mk II measurements shared by restorers. The best‑documented “original‑spec” dimensions match the Serck copper/brass units used on Mk I cars.
Dokładne, fabryczne rysunki chłodnicy do GT40 z 1966 roku nie zostały publicznie udostępnione, jednak najbliższe potwierdzone dane pochodzą od firmy Serck (oryginalnego dostawcy) oraz z pomiarów modeli Mk I/Mk II wykonanych przez restauratorów. Najlepiej udokumentowane wymiary „oryginalnej specyfikacji” odpowiadają miedziano‑mosiężnym chłodnicom Serck stosowanym w modelach Mk I.
  • Ford GT 40 Radiators Restored and Fabricated – The Brassworks
Closest Verified “Original‑Spec” Dimensions​
These measurements come from restorers referencing original‑type Serck radiators (Mk I), which are the closest surviving match to 1966 GT40 units:
Radiator Core (Mk I / early Mk II)
  • Core width: ~24.4 in (620 mm)
  • Core height: ~12 in (305 mm)
  • Core thickness: ~2.0 in (50 mm)
  • Rows: 2‑row copper/brass
  • Inlet/Outlet: 35 mm (1.4 in) each
Overall Dimensions
  • Overall width: ~29 in (730 mm)
  • Overall height: ~12.6 in (320 mm)
  • Overall thickness: ~2.2 in (55 mm)
These numbers match the closest reproduction of the original Serck radiator, which is why restorers use them as the benchmark.
Metadane kart przeglądarki Edge użytkownika. Karta z to aktualnie aktywna/wyświetlana karta użytkownika, natomiast karty z to inne otwarte karty działające w tle.
Overall Dimensions
Thanks for the information. I'll get to work and try to recreate it according to these dimensions.
Paul T.
One thing to mention on the original vertical core radiators with both hoses at the bottom there would be a baffle in the lower tank to make it a double pass radiator.
I noticed in the photo that there's a partition divided into two. I'll make the same one and the second one divided into four and see which solution will have better performance.
Vinny P​
he shared it with me
Are you looking for Mk1 or Mk2 radiator dimensions, they do look different. 1011 is a Mk2.
I need one for my GT/1011, MK2, but I'd love to compare the differences, and if I do, I'd do both types for the MK1 and MK2. Do you have any information on the differences? Maybe some dimensions or other information?
Vinny P
This is what I found:
Notes on Authenticity​
  • Mk I and Mk II radiators were extremely similar, both built by Serck in copper/brass.
  • The Mk II (427 cars) sometimes used slightly thicker cores for endurance, but the external dimensions remained nearly identical.
  • No official Ford blueprint has ever been released publicly; restorers rely on surviving originals.
  • I looked it up on Copilot, AI that can find reverse-engineered drawings of the originals.
