Bob,
100% correct as your two lower links are co planar and you should not get bump steer.
Jim,
first sentence is correct whilst lateral links are co planar
have you considered that when you apply caster the 2 lateral links are no longer
co planar ????
This is where (for my humbling lack of experience) the easy part of this 40 suspension becomes mucked up with anti-dive angles. Does the anti-dive create a toe-out situation on compression? If so, is this why caster in the rear helps reduce this effect?
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com<img src=" /><o></o>
If so, I would then assume that:<o></o>
<o></o>
By moving the front point for the trailing arm outward (which causes toe-in much like a semi-trailing arm suspension will do) by the same amount that this point has been moved upward (for anti-dive), I’ve in essence canceled the two effects to some degree (shifted the bump steer curve around to benefit the loaded wheel at the expense of increased toe on the unloaded wheel.<o></o>
<o></o>
I feel a headache coming on. <o></o>
