Spring selection
I did a search and came up empty handed on this so here goes.........
How does tire size influence spring selection for shocks? When using a 17" tire vs the 15s, how do you take into consideration sidewall deflection? Is it a nominal impact, or a serious consideration? I'll be using a dual Eibach spring set up based upon the good results my UK friends have had. My shocks will likely be the Koni 3012 item as they are double adjustable and rebuildable.
Brian
